- Joined
- 27 Jan 2008
- Messages
- 25,107
- Reaction score
- 2,922
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I would not think the HSE will accept any excuse for working live on a domestic premises it is an jobs worth!You can disconnect the circuit cables from the CU and IR test them seperately without turning off the power. You can also do your continuity tests whilst disconnected. Then Zs, Ze and RCD can be measured once it is reconnected. You won't have to turn the power off as long as you take suitable precautions whilst working live. You haven't mentioned an incomer RCD, so this shouldn't be a problem.
Part 3: Essential Tests No 3 Earth fault loop impedance is surly Zs?On a minor cert the only tests you are asked to do are
IR
EFLI
Polarity
RCD
No mention of Zs or Ze. Of course you need to check that the main bonding is in order.
Cremeegg I fully agree.
ScopeWhere does it say in the regs that you must issue certification when you haven't added or altered anything?
Next thing you'll be telling us you need an MEIWC to change a lamp
The Minor Works Certificate is intended to be used for additions and alterations to an installation that do not extend to the provision of a new circuit. Examples include the addition of socket-outlets or lighting points to an existing circuit, the relocation of a light switch etc. This Certificate may also be used for the replacement of equipment such as accessories or luminaires, but not for the replacement of distribution boards or similar items. Appropriate inspection and testing, however, should always be carried out irrespective of the extent of the work undertaken.
I can't see reading that there can be any way it is not required!
