That's because it draws no more than 3 Amps, which can be supported by a ring final circuit (aka ring main) or a fused connection units. Mira says that an FCU "must" be used.
...it doesn't have it's own trip on the main board.
Do you think thats because it doesn't need one (as it's hot and cold feed) or it's because it's been fitted incorrectly after the house has been built?
