My Mira Flight tray arrived yesterday and immediately it 'looked' bent like a banana. I dismissed it but when I put a plasterers edge along it, it was out by around 5mm or so in the middle measuring along the top edge and measuring the bottom edge of course meant that it was 5mm or so at both ends.
Maybe it's OK for it to be like that, but I didn't see how. Has anyone else experienced this?
I spoke to Mira who explained that there is a tolerance of 4mm in their manufacturing process and it would settle down once fitted. I pointed out that once fitted into a bed of sand/cement it was going nowhere, so would stay bent.
They suggested siliconing it. I asked how I would be able to silicone the ( bent) base to a ( level) plinth. The answer wasn't clear, except to reiterate that there is a tolerance and there is some flex in them. Stone resin - flex?
I then asked how the shower doors would fit if the tray was 5mm lower in the middle. Again, not sure.
I said that there would a permanent puddle in the middle of the tray if I fitted as it is, but they simply said that it would 'depend on how it was fitted'. As per the instuctions I said, LEVEL.
Then they wanted some pictures to show the 'discrepency' but then changed that to, go back and exchange iit. Not easy because no-one STOCKS these trays in my area, which is why I had to get it ordered in the first place. They agreed that actual stockists were an issue.
I'm surprised by the quality checks that were done at Mira, I thought they were supposed to be one of the better companies?
At the moment, I have it in my front room upside down on wooden battons at either end and a heavy drill kit in the middle. It appears that there is some flex in these trays, but whether it will un-bend it, I dont know. As a back up, I have ordered another tray and will check it at the suppliers before I do anything else. In addition, I have ordered a riser kit because over-adjusting the middle legs seems to be the only way that I may be able to 'force' the tray straight at all.
