I’m not sure what it all means so I’m not going to get to excited about it. I’ll run with it and if it fails you’ll see me paddling my canoe down Halesowen high street
Yes, and do remember that is their max rated pressure, usually gravity would only be about half that. Only other caveat I would add to that is ensuring that the PRV's fitted can flow enough to satisfy the pump. With 12L/Min @ 0.01bar I am not sure if the flow rises exponentially with the pressure, i.e. how much more will it flow if @ 0.1bar and the same @ 1 bar if that willbe the sustained pressure.
All moot really as you are aware that it is not designed for that - forwarned is forearmed.
