A
Andrew Haughton
I have worked flat out to install a new bathroom before xmas only to find the shower runs cold, (no power problem).
Here's the way I did it and I hope other relevant facts:
Its a 1st floor bathroom in a small 10 year old house. The shower is above a bath with 22mm mains supply ( since we had a combi boiler installed recently.) There is a pressure adjustment valve (showing just under 1 bar, I think) on a 1/2 inch pipe in the loft but I imagine this feeds only the ensuite on the other side of the house as if it goes to the bath then the pipe thickness seems wrong. So far as I can see the cold flow in the bath is a good healthy rate. The shower above the bath is connecetd via about 6 of 1/2inch copper which has just 2 hand bent bends in it - about 6" radius so minimal resistance I would imagine?
I think the unit is faulty and so does my electrician who connecetd it up to the consumer board but as its me who supplied it and plumbed and wired it, its up to me from here. Mira will charge me to come and sort it out if its a water pressure problem. The pressure according to mira should be no less than 7 bar (or is it 0.7 bar?, I hope you will know!)
My question therfore is whether or not it could be a pressure problem and what I can do if it is.
Andrew
Andrew
