Hi chaps,
Our windows were fitted five years ago and, like in many cases, clearly the old wooden frames were supporting the outer skin of the brickwork, and the fitters didn't address this. Luckily we have low eaves on the 1st floor so it's not a problem (no bricks above windows), and the back windows at the bottom have all been knocked through with various extensions, so my problem is limited to only two windows at the front of the house.
You can see the cracks opening up...
My plan is to use a couple of strongboys, pull out the soldier course and a couple of side bricks, install a galvanised angle iron (60mm x 60mm?) and then re-set the bricks. However, the bottom of the soldier course is a bit lower than the mortar course that I'd fit the angle to. Am I missing something here, or do I just need to bite the bullet and cut the bricks to suit the height of the angle iron, then fill-in the resulting gap over the window with one of those naff UPVC filler strips?
Gary
Gary
