Scenario is:
Have an old FERM mitre saw which is no longer produced. Want to use it to cut some thin aluminium angle so want to change the blade to a metal cutting one. However, cannot seem to source such a blade anywhere. The blade is 205mm diameter and 30mm bore.
I can source smaller diameter blades with a suitable bore which would cut the angle BUT...
Question is whether I can use a smaller diameter blade on the saw?
As always, your expert views would be appreciated.
Thanks in advance,
B
Thanks in advance,
B
