Mitre to smalll tile
18 Oct 2024
I need to mitre the long edge of a 200x30x20thk limestone tile which is giving me a headache. It's these mosaic tiles, but I need to install a couple of them in a stretcher bond arrangement around the front face of a fire place, with the herringbone mosaic inside the actual fire chamber.
It's an outside corner, about 110 degrees. I don't need a perfect mitre, I just need to take enough material out to get the two tiles close enough to get a grout line between them.
I'm going to try and make a wooden jig that I can sandwich clamp the tile in and then run them through my cheap wet cutter to keep fingers out the way. Any other ideas?
Stick to hardboard or something with hot glue gun.
Cut with wet cutter or angle grinder.
Remove hardboard.
Hot glue is easy to remove after.
Is that what you wanted to do?
