I’m trying to work out why my proposed wiring is wrong.
I’ve got a caravan and sometimes it is hooked up to a mains supply. When it is there is a RCCB on the supply and another in the caravan.
I’ve fitted two twin sockets with USB charging ports and they are on a spur. I’ve fitted a 30A double pole switch on the supply side. This is simply because I like to leave the leads that charge my phone and tablet etc plugged in and they have LEDs and it is good to switch them of in some places.
We sometimes go to caravan sites with no mains hook up and I want to fit a couple of USB points that are run off the internal 12v battery.
I thought that using one pole of the switch for the 230v and the other pole for the 12v would work but I wonder if there is any reason not to mix LV and ELV in one switch.
As I see it there is no reason not to use one pole of the switch for the 240v and the other pole for the 12v but it seems wrong and yet I can’t see why it is wrong. The switch must be designed to be safe with a 230v live on one terminal and 230v neutral on the other.
I’d appreciate any sensible advice.
