Hi - just posting to see if anyone's had a similar problem to this:
I've been having intermittent problems with my hot water temperature going from hot to luke warm - not just in the shower but in sinks around the house. Over a two year period and many call outs I've had a new heat exchanger fitted in the boiler and a limescale inhibitor on the mains water inlet. A brilliant British Gas engineer came round today to fit a new heat exchanger. As he went to install it he isolated the hot water feed in the boiler and to his surprise cold water came out of all the hot water taps in the house. He said this was caused by a faulty mixer valve that was letting mains water enter the hot water feed and was probably caused by grit getting underneath a diaphragm in one of the mixers. By a process of elimination he identified the faulty valve as the one that operates my bath and shower (just my luck that it's the most expensive one to replace and concealed behind the bathroom tiles!)
Does anyone have any advice to offer on how easy it would be to repair the valve/diaphragm or should I just buy a new unit? At £300-£400 they seem a bit expensive and this faulty valve is only 4 years old.
Grateful for any advice. Thanks.
