Not these days. It used to be, but you would require a copper flylead now. Mind you it's been a long time since I've seen anyone using the containment for earth on a new installation.
Thanks. That's what I suspected.Not these days. It used to be, but you would require a copper flylead now. Mind you it's been a long time since I've seen anyone using the containment for earth on a new installation.
I've seen a good few duff earths using this system.
You may well be right there adam. I just assumed from seeing a lot of older installations with out the fly lead fitted that it did not used to be a requirement.
Thanks, thats all I needed to know. I didnt think it sounded like a good idea a but I thought I'd check first.
Do you think that reliance on something as user-disturbable as the tightness of faceplate screws would have satisfied the second sentence of D.29 above?.....
D.29 Every earth-continuity conductor formed...by...conduits...shall have a resistance not more than twice that of the largest current-carrying conductor of the circuit. All joints shall be mechanically sound, electrically continuous and protected where necessary against corrosion.
I can't find any mention of fly-leads.
Given that you said that there was no explicit mention of fly leads, I was just asking for an opinion! However, the answer is hardly relevent in 2013Perhaps you could consult the 14th and tell me.
Sure, I realise that.I just looked to see if there was a specific mention of fly-leads, because it is true that there must be countless installations out there with none, where the earth connection relies on the fixing of the accessory to the back box.
Agreed - I suppose that's why I asked whether you thought that "...All joints shall be mechanically sound, electrically continuous and ..." in D.29 may have been meant to indicate that a situation without a fly-lead (although not explicitly mentioned) was not acceptable for earth continuity.With this in mind, if the regs did not specifically say, " A fly-lead must be connected between the conduit and accessory to ensure earth continuity", then it is quite possible that it has been oft-omitted.
It seems to require that for metalclad sockets but not for insulated ones.I suppose the answer is obvious, but do I take it that BS1363 requires (and has always required) that sockets are manufactured such that fixing them (satisfactorily) to an earthed back box effectively connects the earth to the socket's earth pins(s)?
