MK Grid plates - screws on top and bottom?
So clip modules in to frame, terminate, screw frame to back box, screw face plate to frame.
I do the first 3 the other way round..
strip the cores, terminate the earths into the frame, screw the frame onto the box, terminate the cores into the switches ( pull cables through the frame holes ) , clip the switches into the frame ( since they mount from the front.. ) and then screw the faceplate on..
this way you are certain that you haven't trapped or pinched the cables with the frame screws..
Is that the correct convension for the earths ?
I terminated the earth cables on the back box ( double size, 6/8w unit) stud and ran flyleads out to each of the grids.
The grid now has 1 x 6mm cable radial (6mm was simply because that's what I had) on a rcbo 30 amp for 2 x 13 amp ovens and a ring circuit in / out for hood, fan, hob and washer.
Nine cables (3 circuit feeds and 6 feeds to the appliances) was a PITA to set in in a tidy, clean way.
The loops on the ring should read supply side !
