Wago have been making spring clamp terminals since the 1960s.we do not (cannot) yet know how Wagos fare after they have been in service for several decades.
The decades of extensive use have already occurred.
Yes, I had been expecting someone to say that - and also, indeed, that 'clamp'/spring terminals have been in use in some commercial/industrial settings for far longer than that.Wago have been making spring clamp terminals since the 1960s. The decades of extensive use have already occurred.
What are the disadvantages, and are these just your uncertainties. As John has posted, the technology has been around for decades.Fair enough - although I would add my usual caution that (in contrast with screwed terminals) we do not (cannot) yet know how Wagos fare after they have been in service for several decades.
As I've said, the main attraction to me is the 'one conductor per terminal' - although, as I have illustrated, that can be (and has been) achieved with screw terminals.
Indeed. If the idea were to 'catch on', the logical result would be that all electrical accessories, of all makes, would eventually adopt this approach. I may be wrong, but I suspect it will remain as a 'novelty', but I'm glad to see that MK have tried it, so as to 'test the waters'!
Indeed - but, as above, also the 'disadvantages' we see with MF JBs in relation to the (inevitable) current uncertainties about very-long-term performance.
Kind Regards, John
I've indicated the nature of my uncertainties, but I have no idea to what extent they are shared by others. I function in fields in which anything has to be regarded as 'uncertain' unless/until there is a considerable amount of convincing hard data/evidence to largely alleviate uncertainties.What are the disadvantages, and are these just your uncertainties. As John has posted, the technology has been around for decades.
They presumably are not 'real Wagos' (don't look like them) (i.e. manufactured by Wago) and I presume that they were created by whoever manufactures MK sockets.Are they actually Wagos, look more like the similar cheap copies that you see on Ebay, would people feel confident buying them rather than the genuine Wagos
I don't really disagree with any of that, other than perhaps to add that an 'amateur' who needs that degree of 'foolproofness' probably should not be wiring a new socket in the first place.I feel it could be a great product to allow amateurs to safely wire up a new socket.
Screw terminals aren't exactly difficult to use, but they can have their issues for the inexperienced - especially when there are multiple wires per terminal. ... Having a built-in wire stripping guage, a terminal per wire and clearly colour-coded terminals; almost makes wiring this socket safely, foolproof!
Yes, but you'll never be able to stop them having a go!I don't really disagree with any of that, other than perhaps to add that an 'amateur' who needs that degree of 'foolproofness' probably should not be wiring a new socket in the first place.
Kind Regards, John
True - I don't disagree with that, either.Yes, but you'll never be able to stop them having a go! You may as well make it as easy and as safe as possible (within reason)
Probably none. The last ones I was aware of being manufacturer or assembled in UK was RPP. I am unsure if they still areWhich electrical accessories are not made in SE Asia?
Kind Regards, John
The 'specs' for sockets (e.g. MK ones) usually mention 2.5 mm² , 4 mm² and 6 mm², but I'm not so sure about 1.5 mm².I thought spec for 13 amp socket allows cable from 1.5 mm² to 6 mm² to be used, but these only allow 2.5 mm² or 4 mm² ....
