MK mcbs
Good, technically you got it. LABC is up to his electrician - this bit of admin does not make is safer. But now no cowboy will come in and say "a new CU guv", and charge the earth.
This forum can be useful at times. Thanks to flameport.
You are talking regs now. The reality is that the single cable will supply double insulated data equipment in a cupboard.
Doesn't matter.
The socket will be plastic.
Doesn't matter.
The equipment will be on 24/7.
Doesn't matter.
It is not a power ring with high current metal kettles & heaters open to people touching the metal surfaces and the likes.
Doesn't matter.
That is where people's safety is then paramount.
People's safety is always paramount.
It will be fine for a few years until update.
No, it won't.
Risk of electrocution on this circuit is very, very low.
Doesn't matter.
A new 32A ring would need the RCD for sure.
Any new circuit with concealed cables or sockets will need an RCD. And Building Regulations notification.
Actually, after a quick look, your link, although far longer than the actual law, seems quite reasonable.
It states:
"2.7 Regulation 12(6A) sets out electrical installation work that is notifiable."
You may notice these two numbers, 12 and 6A at the beginning of the page in my link.
He doesn't seem to have noticed this:
