It's not exactly a Herculean task to dig the filler out....It would have been handy of there were accessible screws to lift the front face of the wooden paneling off, but these have been filled in with wood filler.
At least bringing the cores and the sheath (that is between the cores and steel armour) in through the wall means the connections ( if any ) are inside the house and thus not prone to weather effects such as condensation of vapour from inside the house / cavity creating water in the external junction boxrather than taking the SWA on through - the latter approach may not work, because if you remove the sheath and armour from SWA what you are left with has to be kept in trunking or conduit, or enclosure(s) of some type.
True if the ducting is not necessary.Not installing the unneccesary ducting is a much better solution.
What BS cable standard applies to the part of a SWA cable you are left with when you've removed the outer sheath and the armour?At least bringing the cores and the sheath (that is between the cores and steel armour) in through the wall ...
