Mobile phone reception
I've got an even better suggestion for all this, height, carry around a tall set of ladders, every time you want to make/receive a call, clime up the ladder, there is even a better signal up there.
im with 3 and had really bad signal at home for years. I threatened to leave them and they eventually agreed to give me a "home signal box". This connects to the internet and act like a mast in my living room and gives me full signal throughout the house. I think all the companies have a similar box so may be worth asking.
Hope this helps
EE/Orange/T-Mobile have these Femotocells too, called Signal Box
Vodafone have a Femtocell as well which I think they call Sure Signal?
That leaves O2, not sure if they have one?
If you are working on site at e.g. a customer house I see no reason not to plug it into their router on site if there is no mobile signal and the customer is happy.
I will write a little disclaimer here though as the Femtocell is registered to your home address so any emergency calls made over it will be dispatched to the registered address therefore it's not so good if you slip with the circular saw, slice your vocal chords and make a silent 999 call!
there is a booster device that simply plugs into a Broadband socket - or so O2 have told me (they are sending me one FOC due to **** poor signal in our area (was with Orange which was OK) I'll try it when I get it and let you know how it works out! ;)
Sounds like O2 have a femtocell as well then - like you said it simply plugs into an Ethernet port on your router.
This post was made on a 3G connection via an EE Signal Box!
Great idea better still can you buy Bluetooth ladders
still stuck with the Nokia 820 still learning how to use it seems to work ok
