utter nonsense. torque only effects acceleration and top speed.
if an engine turns at say 3000rpm then it will produce say 70mph at the wheels (assuming correct gear ratios).
allow a long stroke engine turning at 3000 rpm - same speed. just not working so hard. high torque less effort.
allow a short stroke screamer turning at 3000 rpm - same speed (may struggle to maintain it) but working hard. less torque more effort.
its all down to gearing. put one speed into a shaft (gearbox input shaft) then you get a different speed out (wheel rpm) engine torque has no relevance (except ability to maintain given rpm)
Exactly! at last someone who can see the correct relationship
For the same gearing it's impossible to derive two seperate speeds for the same revolutions, they are inexorably linked, one RPM is one RPM irrespective of torque.
Wotan
