Here's the result. Bear in mind that this system was thoroughly flushed through the boiler fill loop down separately the flow and return each having its own drain off.
Filled up with hot (showing 45C once in the pump) supply from combi and turned on. Water went straight to black. So PF and hot over mains cold is a clear winner.
Having dumped back to clear water, the Ferroquest didn't create the same drama (even when up to 55C) but this system has no old rads, the only old being in total about 35m of 15mm which made the amount of dirty water surprising.
I accept that the mains flush wasn't following a 'used in the system' chemical, which would be far better than just mains, but I'm a happy bunny for my £1200+. Magnaclean next I suppose at what, another £250?
My prices have just gone up!!!!
