- Joined
- 18 Feb 2007
- Messages
- 1,389
- Reaction score
- 79
- Country
Has anyone got any thoughts on These Night Lights they have been around for quite a few years so
I have purchased a Moonlight and was very impressed with it's light output, however I decided to check the claims of the light with respect to 4.38 kWh per year if used continuously for 24 hours per day 365 days per year.
See http://www.ecohamster.co.uk/product...cts_id=8662&osCsid=b8q73kmkreosvvfs0ah20kkv04
I measured the current drawn by the Moonlight on 240v and found it to be 23.8mA, this equates to 5.7W, assuming unity Power Factor. Now, if the light is used for 24 hours per day for 365 days (ie 8760 hours), would result in a power consumption of 50kWh. which is in fact over 11 times that which is claimed.
In order to check my test instruments which was a Digital ammeter, I inserted a 9W bulb into the circuit and my test instruments confirmed a current of 37mA which is correct, As a further check I used a 25 Watt incandescent bulb and again recorded a current of 104mA. This being correct, it confirms the calibration of my instruments.
For the claim of 4.38kWh to be correct, the power consumption of the Moonlight should be 0.5W and as such the Moonlight should only draw 2mA, infact it draws over 11 times this at 23.8mA.
These calculations are assuming, as stated, a unity Power Factor. In order to achieve the power consumption claimed, the power factor will need to be around 0.1, suggesting that the lights are almost totally Capacative.
Any comments anyone - not sure whether this post should be on General DIY or General Discussion, if I get no repsonce here I will try the other Forums.
