Hi all!
I had a condensing boiler fitted a few years ago and now need it re-locating. A friend of a friend is a British Gas engineer and ‘does foreigners’. Will this be covered by gas safe?
If not, I’d rather go elsewhere to get all the certs. I’m having it moved from the garage to inside the house, and it’s pretty much in exactly the same place, just on the other side of the wall (if that makes sense) all the pipes are pretty easily accessed in the under floor void, and the gas pipe runs along an external wall and only needs to be extended about 300mm. Am I asking a bit much for that to come in at around £500?
