I am installing 6 sofit lights across my front roofline, but i am having problems working out whats what with the transformer i have bought (PRI:220~240vac 50Hz 25VA SEC:12vdc 1.67A Max.20VA) with its funny block connctor for each individual light ?!
I just want to run from the first to last light with no 'loop or return wire, just like the 2 packs of LED garden lights i have just discovered in my garage ! 2 packs of 3 LED mini posts & each with a 12V 840 mA 10.08va transformer. So if one transformer will feed all 6 garden light posts then i have 1 spare transformer for this project !! And it simply plugs in & has a 2 pin output port ! Wow please say this transformer will work !!! Is it the solution to all my problems !?
Like most people Amps, Ohms, Volts etc etc are another language !
I have also found a transformer marked - "12~3A 36va" ??
Also i do have a fair run, furthest light is 15 feet up & then 25 feet across i think, will this mean i need an LED driver or more Amps, current, flow or something ? Is 1.5mm2 lighting cable too heavy ? If the above transformers are no good & i return my origional "funny" transformer, what transformer do i need or should i just revert to mains !? I have forgotton now why i bothered with 12v in the first place !!
