I was just thinking about those games where you have a wire bent into a shape, and you use a ring-shaped thing around it. You try to trace the shape with a steady hand, and if you make contact, a buzzer sounds and you lose.
Well, I thought: you could have that same game, but with the bent wire connected to neutral and the hand-held bit to live (obviously with an insulated handle). Connect it up to the lighting circuit and it would be great fun to play. If you lose, the RCD trips/fuse blows, preferably with some sparks as your handheld bit is spot-welded to the shaped wire. Plus the loser has to go to the CU and fix it. Brilliant.
Any other games that could be made more fun through the application of DIY? "Stuck in the mud", played with No More Nails?
