Depending on span, if we are using 50x100mm commons we would make hip rafter 50x150. How ever if you already have bought a 50x100, don’t worry, it will be strong enough.
Why?my box lintels aren't adequate due to them not being cavity lintels, so I'm going to have to swap those out for cavity/top-hat lintels, even through there will be no weight on the outer leaf.
We agree with Nose 100%, he is right in all that he has said. However saying that we had a similar problem three years back and we lost three days arguing about it with BC. For some reason or other they don’ t like the Catnic Clasic Box eaves lintel, so now we always fit open back Catnic CGE 90/100 or IG L1/E 75 for 70/100. As both the above lintels usually have to be ordered, we just use standard open back. The only difference is a standard open back is 283mm wide and open back eacves is 248mm wide. Think I have remembered them right.Why?my box lintels aren't adequate due to them not being cavity lintels, so I'm going to have to swap those out for cavity/top-hat lintels, even through there will be no weight on the outer leaf.
We always use a box lintel above an upstairs window whereby it becomes an eaves detail as opposed to say a gable. As you say, all there will be above is fresh air. The box sits upon the inner leaf and the soffit board sits directly upon the outer leaf.
The only thing i can think of is the window span is above 2m and the strength issues with a standard box will not comply. You could install a HD spec box if necessary?
Otherwise using a lintel with a lip or an outer carrier is not only pointless but it interferes with the soffit.
Do you have a course of bricks above the windows?
I can not think of a single reason why a (two course) box lintel would not be satisfactory.The widest span is 105cm. There's no course of bricks above the windows on the outer leaf, it's all as per one of my earlier diagrams (see below)
For example:
A 1050mm ST 100 box will carry 23.52KN.
It will not only deal with your roof.... it will EAT IT! icon_confused.gif icon_rolleyes.gif
