- Joined
- 28 Jul 2014
- Messages
- 1,968
- Reaction score
- 561
- Country
A/F on a pentagon? Can you elaborate, rs?
Re-read the text I quoted of EddieM's, in particular, the word I changed to bold originally. Note that I've not edited that post at all.
on a pentagonal socket, where would 10mm be, point to point, point to flat or flat to flat ?
What are you up to, Eddie?
John
No problem with that - its just the hardening and heat treatment which may give you grief.
Machinists use a 'dividing head' attachment on a milling machine to get the accurate angles.
John
Sure, but it all depends on the carbon content of the steel whether it will harden to any degree. Mild steel doesn't harden to any extent and doesn't readily work harden.
What you would do is to use a high carbon steel and heat treat it by the oxidising colours....an example for a cold chisel - if I recall - is to heat the chisel up in the middle, and when the blue colour travels down to the chisel blade, quench immediately in water - sort of freezing the hardness where it's needed.
I'm a bit rusty (!) concerning this now but Google will come to your rescue.
John
I used to do secure works in banks. They specified that all fixings had to posidrive type and you then drilled out the posidrive head.
