We had a Vaillant ecoMAX 835 fitted 2 years ago and have had loads of problems with it coming on when it shouldn't or not turning off. It appears that this is simply due to a communication problem between transmitter and receiver (of which we've had countless replacements and moved the tramsitter closer to the boiler). The transmitter is a dual thermostat and timer.
This week in an effort to conclude that it is this problem Vaillant have removed the receiver and replaced it with a manual timer at the boiler, so we set the temperature of the boiler and set the timer when to come on and go off.
After this test I will probably be left with a choice of keeping a manual timer and regulating the temperature using the TRV's, replacing the transmitter with a hard wired one or trying yet again with a wireless transmitter.
We live in a bungalow with solid internal walls and no close neighbours. All of the radiators are fitted with Mistral TRV's with three of them fitted with Chartwell brass TRV's. Our new radiators in the living room and bedroom are adequate for the room sizes using 60 deg. to work out the BTU's. Some of our older radiators are clearly not big enough to heat the spaces they were put into, including the large hall where the tramsitter/thermostat is fitted. It is not an option to put the transmitter in the living room it would have to remain in the hall.
So my question is which would be the most cost effective way of using gas at the boiler to heat our home.
1. Use a manual timer at the boiler and set the heat at 60 deg. setting each TRV to adjust the temperature for each room.
2. Use a manual timer at the boiler and set the heat according to the season, eg. higher than 60 deg. in winter and much lower than 60 deg. in summer, then setting each TRV to adjust the temperature for each room.
3. Using a trasmitter and receiver (thermostat and timer) having the boiler set at maximum.
4. Any other suggestion.
Thank you in anticipation.
