The Haynes manual says it should be around 7bar which is just over 100psi. A low reading in all cylinders.
I disconnected the lead to the rotor and spark leads, took out all the plugs, took the fuel pump fuse out and pressed the accelerator pedal all the way in while i turned it over with the key. All cylinders shot up to pressure nicely and I stopped turning the engine when they levelled out at around 4 or 5 turns...
Still, a low reading but somewhat similar...
