- Joined
- 30 Oct 2006
- Messages
- 6,751
- Reaction score
- 381
- Country
What if someone wants their seat in a fixed position never to move and has made it so?
If it has no mechanism it can't be checked.
The Supra is not an import.
Do you know if that Emissions listing publication is available for anyone to reference?
BTW, I'm pretty sure I can still buy the front pipe without a cat.
This appears to be the O-fficial word on the steet:- http://www.dft.gov.uk/vosa/repository/MOT Inspection Manual.pdf
DIY ICE enthusiasts had better secure their wiring!
Also sounds like there is no room for a fixed seat.
Interesting. Cars like the Marcos (and I think some other niche sports cars) had fixed seats and the pedal box was adjustable. I assume they're going to add some clarification shortly to say that "fixed seats, if original equipment, are ok"!
The flow chart on pag 9, about finding an exact match in the database, only refers to vehicles first used after 1992.Basic Emissions Test (BET) Vehicles first used on or after 1 August 1992 – (1 August 1994 for Class 5 vehicles)
Early catalyst equipped vehicles may not require a ‘CAT’ test. The flowcharts and notes must be carefully followed.
My other concern, the '95 Disco now without a cat doesn't seem to be listed at all.
In the "Compression Ignition" section there is no reference to cat or non-cat tests.
Thanks guys for those links.
I think I'm still a little perplexed though.
gman's link to the MOT manual shows that the emmisions reading for the Supra 7M-GTE should be CO <=3.5% and HC<=1200ppm. From the flow chart in section 7.3 page 6. Cars first used between 1986 and 1992.
This is for a non cat test.
The BET page 8 shows that it is exempt form the BET.
But the Supra does appear in the Emmisions Data Book in Avocet's link
shown here:
View media item 41039
So the only conclusion I can deduce is that the basic standard of 3.5% and 1200ppm is applied. This is also reinforced by the statement on page 2
I can't see any reference to cars originally equiped with a cat, but no longer having one.
Does anyone arrive at a different conclusion?
