Motor system failure
Just make sure your battery terminals are tight first! It sounds like either a dead battery or a high resistance somewhere. You could try putting a jump lead from the battery negative terminal to some good, clean metal on the bodywork, and another jump lead from the battery negative terminal to good, clean metal on the engine. If it is no different, (and the battery terminals are tight and free of corrosion), then it is probably the battery.
Battery,i charged it overnight and it works now but i will replace this one probably since i had a lot of problems with this car battery the last few months,also the terminals on the battery are in a really bad shape,i could not connect the positive connector properly,all the way down,i will try to clean them and maybe still use this battery for some while
Once a lead-acid battery has been completely discharged half a dozen times, its days are usually numbered!
