if i switch on my central heating at my boiler...the actuator will move but not quite far enough to switch on the heating...this i have to do manually via the lever... the problem is'nt a sticking valve because i have tried the actuator with it removed from the valve... i have also replaced the actuator & the same problem still occurs... also when the lever has been manually put in the locked position,the central heating will come on but also the hot water...please help...
