- Joined
- 2 Jan 2019
- Messages
- 335
- Reaction score
- 8
- Country
If the felt is breathable the condensation shouldn't be that bad. I have a similar issue. I insulated the loft to the required standard and it caused condensation. I used felt lap vents and they do work but you have to be careful of wind uplift. It's hard to find advice on lap vents. But your suppose to install them as close to the eaves as possible. In every other stud kind of thing. Also install a couple further up from the eaves, closer to the top. Don't install them directly opposite either or the wind will just blow straight through and won't circulate. Ideally you probably need some kind of roof ventilation like me. Once the weather gets better I'll be getting three roof tile vents at the bottom and two at the top on each side. Hope this helps
