The washing machine's back and left hand side sit against a solid stone wall so guessing moisture is condensing on the cold wall. Any ideas or help will be appreciated. Thanks
If the water supplies are conventionally fitted then the W/M is being supplied by the hot water feed.
I was referring to the supplies in the pic.
Two 15mm copper pipes can be seen dropping down - the one on the left is feeding the W/M.
