The extremely wet winter of 2013/14 has tested the damp resistance of even the driest UK properties.
Short of full air conditioning, increasing air movement is the only way that will solve domestic condensation problems on walls behind furniture etc., in corners at the bottom and top of walls, on and around windows, and the cheapest way is to use the fans that you would use in summer to move air about when it is too hot.
Condensation occurs on surfaces that are colder than other surfaces in the same room.
If all surfaces are as warm as the air within the room, condensation can not occur.
Reciprocating or oscillating fans will move air to contact large areas of surfaces in a room, warming the surfaces to ambient temperature. Because surfaces are being warmed that were not when the air was still, the heating system will work a little harder, especially when previously damp surfaces are still evaporating, and thus chilling.
Without air movement, dehumidifiers, trickle ventilation, or even turning up the thermostat for room heating. will have limited effectiveness in controlling condensation.
But this is putting the cart before the horse, since there are mould spores on the damp surfaces (in fact everywhere where the air can carry them.)
Actively growing mould patches need to be treated first. Then a thorough cleaning of dusty surfaces, using damp cloths and dilute bleach, and a vacuum cleaning of all carpets, floors
The cheapest, rapid, and most effective treatment of black mould (Aspergillus) and pink mould (Serratia) is bleach.
Neat thick bleach is most effective and will not harm walls painted with emulsion or gloss painted woodwork. Apply liberally with a nylon brush and do not scrub the area. Allow to dry. The mould will vanish in a few seconds.
Bleach is an irritant to mucous membranes so ensure ventilation while treatment is in progress and for a time afterwards.
Polyester carpets should be unaffected, but wool, untreated wood surfaces, and other natural materials may be affected by the bleach treatment. Test a small area first. A less harsh treatment is a quaternary ammonium based disinfectant, such as Dettol antibacterial kitchen surface cleaner, but this will not remove the black stain.
The dampness may have already damaged the painted surface or wallcoverings. Bleach will remove most staining, except where the mould has penetrated deep into silicone sealants, and the best remedy here, is to cut out the old seal and redo with a fresh mould-resistant sealant.
http://www.youtube.com/watch?v=SKOuiOKhULQ
Or else you can do this:
http://www.youtube.com/watch?v=Pzd0bz828nk
This guy has a more reasonable response:
http://www.youtube.com/watch?v=Oj99RNY55Es
