Hello
I bought one of these, weight 16.1kg without stand: https://www.richersounds.com/tv-projectors/all-tvs/sony-bravia-kd55xg8196bu.html
The recommended bracket in the manual is this, though only seems to be available at this shop: https://comwales.co.uk/sony-suwl450...MI3qixuO3B6gIVhe3tCh3AzwAfEAYYASABEgKZhPD_BwE
In another project I used these to fix slot shelving to plasterboard (tried in vain to find studs using stud finder and drilling 2mm pilot holes at sensible distances apart!), repairing fix by previous house owner who used the "screw in" type which were coming out at the top (had to repair wall hence didn't care about pilot holes above!) ... https://www.screwfix.com/p/rawlplug-hollow-wall-anchors-m6-x-52mm-20-pack/68410. So far so good
Questions:
(1) Do you think the above solution would be suitable for my TV? I only want to use a fixed bracket, not one of those which sits way out of the wall and moves about
(2) Obviously there's loads of different brackets on the market other than this one, any recommendations?
(3) My stud finder is picking up studs, I could mount SOME screws in there without sticking on a piece of plywood / MDF which would presumably improve things?
Thanks, Paul.
Questions:
Thanks, Paul.
