Hello All;
Have just exchanged on my first house (the house I been renting) and doing some minor renovations downstairs, which includes replacing the floors, removing wallpaper (finally can) and a raft of other things ... which means a bit of a construction site, but an opportunity to perhaps lay down some cleverness for networking / media services.
At the moment, the house is supplied by BT for internet and Sky for TV, but as I am in a Virgin area, I will be moving to them (been holding off, because of this question).
Downstairs, in the current lounge where the BT wall socket is, there is a older white box next to that, that says "Cable Wireless" and after some research that appears to a old NTL box.
As my OH is remodelling the lounge, which is changing it's "role" into a dining room and the lounge/tv room is moving to the other side of the house (closer to the back garden) ideally she said she wants the "clean" look - which in simple terms is "None of that technology crap on the wall".
So it dawned on me, perhaps I could actually get this wall box moved to be under the stairs (out of sight) and have the Hub in there too.
Obviously I'd ask Virgin to do this and pay the £99 fee for moving it all ....
So wanted to get a sense check if I am on the right track:
1.) Get Wall Box moved to under the stairs (not sure if the cable that runs from outside to the current box is modern / works | but that's for the engineer)
2.) The hub will be in here too
3.) Run the coax cable under the floor boards within a conduit or duct thing, to the new lounge
4.) Include 2 or 3 CAT5e / 6 (not sure which) in this wiring, to the lounge (thinking PS4, Tivo, AppleTV)
As the Hub is now under the stairs, I am more than certain that this will screw the wireless and have interference. So then I have some further choices:
1.) Hardwire my ASUS-5300 monster to the Hub and find a strategic place to put it, that my wife doesn't mind seeing it (Spare Room, about 10m away ... need to figure out the wiring for that)
2.) Put in a nice looking (she seems to like the modern look of it) Wireless Access Point such as: https://www.broadbandbuyer.com/products/23765-ubiquiti-uap-ac-pro/ | which I can put just outside the "under the stairs location" above a doorway, where a old alarm used to be located.
Any comments, thoughts, suggestions, views .... ?
