I am moving a consumer unit about 5 metres to the right of its current position. The existing consumer unit (BS3036 fuses) terminates almost at ceiling level. Once I have removed the existing consumer units I want to connect all of the circuits into connector blocks mounted on a din rail inside an insulated enclosure(obviously keeping all PNE seperate to preserve the integrity of the circuits).
From this enclosure I will run all the circuits in large trunking to the new consumer unit position. At the meter end I will put in a 100a DP switch and then run 16mm2 swa to the new consumer unit. Obviously I will do all necessary inpsections and tests before commmencing the work, I already know the equipotential bonding and main bonding need upgrading.
My questions is this, can anybody point me in the direction of a wholesaler who sells din rail mountable terminals? Please dont point me in the way of crimps, I have all the gear but have found a couple of times when testing that crimp joints are unsafe, and have had to cut and redo. Any other advice gratefully received
