just a member of public offering an opinion, if you really believe my views have no credibility and I am not a gas fitter then why should it be considered advice?
turns out that most of the run will be under the new floor. I was going to use joists and cover with 18mm chipboard but BOC say as my floor is level I should just lay celotex and cover with the chipboard (glued joints) as a floating floor.
I need to raise the floor by 198mm so I plan to use 2 layers of 90mm celotex. Can I leave this gas pipe as it is and cover over with the celotex?
