I would like to wall mount my tv in my downstairs living room to an external wall however I need to get a power socket on the wall somewhere behind where I am proposing the TV to go.
The house is a new build and the developers put a spur socket (off a double ring main socket) to be used for an electric fire. The spur comes from the double socket, to a fused switch and then finally from the switch to the end socket which is roughly 2 metres ish.
I would like to move this spur socket up the wall by about 30-40cm as it is the closest power source and it won't get used for anything else. So my question is how to I go about doing this? The fused switch and the single spur socket are directly horizontal to one another and I am guessing that the electric cable will be attached to the thermalite block underneath the plasterboard.
The first thing I thought of was turning the existing socket into a junction and just running a new socket off of it higher up the wall as it seems the easiest but that leaves me with having to leave the junction accessible by way of a removable cover/plate.
What else can I do?
What else can I do?
