No but you are , Boilers and lofts do not make good bedfellowsNormal floors aren’t that thick are they?
Ooh, touchy! You seem to be about the only plumber on here that doesn’t like boilers in lofts in case they need resetting every blue moon. Ah, I get it - you’re one of those that ‘don’t do lofts'. You like boilers that are fitted where it’s convenient for you to get to once a year. Where’s your boiler fitted - next to your armchair in your lounge for convenience? As you assume I’m thick, I’ll assume you're either fat, lazy or just scared of heights. Maybe all three?No but you are , Boilers and lofts do not make good bedfellows
Possibly but how much water is there in a boiler compared to how much water is in a cold water storage tank or vented expansion tank and they fit those in lofts. I would think there is more chance of suffering from frozen pipes in a loft without a boiler.Any leaks are straight through the ceiling..
Mines a heat only, sealed system so a gallon at most if a boiler pipe froze and split.Not necessarily the boiler, it depends if it’s the cold main that freezes, or even the hot water pipe fed from the cold main (on a combi of course). If it’s heat only, still a tank.
Im not a plumberOoh, touchy! You seem to be about the only plumber on here that doesn’t like boilers in lofts
I dont have a fear of lofts, they are just no place for a boilerDidn’t think so. It’s the fear of lofts that gave it away.
how dare he call you a plumberIm not a plumber
