I currently have installed a gravity water system (hot + cold taps) with a fully pumped, Y plan open vented heating system, in a normal 3bed semi. Im now looking to have my hot water cylinder, heating pump and controls moved into the loft under the water tanks.
The water tanks are situated on a stand in the apex of the roof and the base of the water tank is 5foot from the roof joists. There is enough space underneath to resite the indirect 42x18 cylinder with heating pump and controls.
My main area of concern is the design of the heating system with the open vent.
Can i still use the fully pumped heating system with open vent? as the vent pipe would be tee'd into the system in the loft rather than lower down on the first floor. Again im concerned about the pump dragging air into the heating system.
I also realize that i could do away with the expansion tank and go "sealed heating system"
Does this just mean adding an expansion vessel, pressure relief valve and filling loop in place of the expansion tank?
If so, how do i size the expansion vessel for my system?
Does anyone have a pipework diagram of a sealed system?
Thanks in advance
Thanks in advance
