Assuming the outside vent pipe does lead to the same place as the soil pipe (using a hose to put water in from the top as a check) I will be removing the cemented in toilet completely and capping off the soil pipe in the floor in the bathroom. A hole would be cut in the wall for the new soil pipe which will align directly behind the vent pipe on the outside wall. The vent pipe would be cut approx 200mm from the ground level removing the top portion of the asbestos pipe, leaving the bottom part which is cemented in to the ground and replacing with plastic pipe using a tee to connect the 3 pipes.
Does this sound ok ?
Incidentally what is the best method to cap off the old soil pipe in the floor of the bathroom ?
Run a hose in the top of the vent. Light a Players Navy Cut ciggie and Enjoy it while waiting for the dreaded fibre to become fully soaked then cut the pipe @ ground level with a disposable saw (£6.00 ). Have another fag, chuck the pipe in the van...and renew the stack all the way in plastic, because when the house is sold some tit with a clipboard will faint when he/she sees the asbestos stub Charge you extra £25 for the danger- (£ 6.00 for the ciggies, £6.00 for the saw, and the rest for wrapping/driving to designated site for asbestos disposal) That`s what I would do. What would a plumber do when confronted with a small asbestos job ?
