I know what your saying but for every click4 there's 2 fly by night bodgers, it's gone on for too long now in this trade where someone with no experience and no qualifications can come and rip out your windows and totally #*@# up an install
Not against improved standards and control, I agree there are bodgers... Some of the biggest ones seem to be companies with teams of installers rather than sole traders. Recently had a look at some glazing for somebody who know. They only had it fitted about 18 months ago and said they have always had trouble shutting front door.
Had a look, and you could see daylight through bottom corner when shut.
Door needed raising up in its frame, it wasn't centred vertically, and adjustments were way out.
Found their patio door in a similar state, the vertical jam where all the locks engage wasn't even vertical and door was too low. Both now lock perfectly.
Even said to somebody other week, anybody can screw a window in a hole, but not everyone knows how to do it properly and in a thermally efficient manner.
So plenty of cowboys yes. And they need stamping out, even here.
Next door neighbour, they had their windows fitted last year, house has tiles on front of house, window installer framed the window with utility board to frame window inside the surrounding tiles. But instead of fixing it to frame first, offering frame into opening complete he fitted it first, then tried fixing the plastic framing trim afterwards.... Result was theres gaps where it meets in the corners where they aren't cut to correct length, and the 6mm plastic is all wavy and sagging.
It is possible to trim the window before fitting as I did it with ours, funny thing was, afterwards the neighbour kept having a good look every day for days... Presumebly because it turned out better than theirs and they didn't like it as they always want to have the best.
Another neighbour down the road, their upstairs window openings practically foul on the tiles because of the tile overlapping lintel.
With ours I had to have window made undersize then add an extension piece to the top to created correctly sized window which didnt foul on tiles.
But as above not against tighter regulations, I don't mind regulations, don't even mind tighter control to ensure regulation is adhered to.
But don't agree on a complete ban on non fensa installers, because people like me generally do a good job and arent a cowboy and it will kill what little work I get from windows and doors.
Had same with electrics, I have all the test equipment, I own copies of the latest regulation books, I've worked with electricians who can't fault my work and are happy with it; had council inspections to get bigger jobs signed off
and nobody has every faulted it.
But because of part P I can rewire a house get it signed off by electricians who have nothing but praise for my work through building control. Provide my own test results with an up to date calibrated test meter... But I can't install a couple of sockets because building control fees make it cost prohibitive.
Luckily with the windows and doors its a bit more reasonable but I rely on building control to allow me to do these jobs. If that access gets stopped then it can be make or break for a small business like mine and to be fair people like myself don't deserve to be driven out of business by a bunch of cowboys.
What needs to happen is for building control to simply tighten their belt, not stop that route... Just make the inspections more thorough.
Whenever I use them here, the guy just goes around, puts a device on the glass, it bleeps then after a few says yep all good and issues completion certificate... That is the problem, personally I want them to open windows and check its a fire hinge if required, feel for drafts, look at how secure it is, and General installation. Ask questions about its installation.
If they did then things would improve.
After all that's what happens with new builds...house is considered inhabitable unless it passes inspection, and those inspections can be quite thorough... Only one I've seen they even commented on gaps in the join on door architrave, and paint on door hinges.
