My current windows are pretty old and on them, I believe, where there was a joint, the joint machine left a lump which was then trimmed by hand and finally polished up. End result is you can't see the join. On new windows it seems like the method now is to press in on the joint. So in the corner of frame you get a depressed slot at the 45deg join. That's not too bad, it's a reasonable finish.
However, where you have say a fixed pane next to a side hung opening pane, you have a vertical mullion. At base of this is a Y joint (and an inverted Y at the top) because 3 pofiles join here. The V part of the Y is a depressed slot as in the corners. But the lower i bit of the Y is proud and looks just to have been milled off to 1mm or something. It's ugly IMO. Why don't they form a depressed Y rather than V? Are all windows like this? Or am just looking at poor fabricators?
Thanks.
Thanks.
