OK, what I expected
Some with me some against
I will take up one point oilman said " why not give a little positive help"
Here goes
A meter is a measuring instrument. An ammeter measures current, a voltmeter measures the potential difference (voltage) between two points, and an ohmmeter measures resistance. A multimeter combines these functions, and possibly some additional ones as well, into a single instrument.
Many household problems can be fault found using resistance and voltage measurements. Most DIY'ers will rarely need to measure current
Testing for Continuity ( resistance )
This test should be done when current is NOT present. Always unplug the device or turn off the main circuit breaker before attempting a continuity test.
A continuity test is done to determine whether a circuit is open or closed. To test the continuity of a circuit requires the use of a multimeter or multitester.
Set the multimeter to the ohm setting. The symbol for ohm is , the Greek letter omega. If there is more than one ohm setting, choose X1.
Note that while the probes are not touching anything, the multimeter will indicate a reading of infinity. A reading of infinity indicates that the circuit is open and cannot conduct current. When you touch the two probes together, the reading changes to zero. A reading of zero indicates that the circuit is closed and can conduct current. Touch each probe to one of the terminals (or poles) of the device. If the reading changes to zero the device has continuity.
To test a switch, place a probe on each pole of the switch. When you move the switch from the off to the on position, the meter reading should change from infinity to zero, which implies that the switch is working.
To measure current.
The circuit must be broken to allow the meter to be connected in series
ammeters must have a LOW resistance
Think about the changes you would have to make to a practical circuit in order to include the ammeter. To start with, you need to break the circuit so that the ammeter can be connected in series. All the current flowing in the circuit must pass through the ammeter. Meters are not supposed to alter the behaviour of the circuit, or at least not significantly, and it follows that an ammeter must have a very LOW resistance.
To measure potential difference (voltage)
The circuit is not changed the voltmeter is connected in parallel voltmeters must have a HIGH resistance
This time, you do not need to break the circuit. The voltmeter is connected in parallel between the two points where the measurement is to be made. ( ( betwwen live and neutral to check for mains supply) Since the voltmeter provides a parallel pathway, it should take as little current as possible. In other words, a voltmeter should have a very HIGH resistance.
Voltage measurements are used much more often than current measurements.
This is simplifying artcles which can be found using Google and typing in
How to use a multimeter
The originator of the thread has a problem with a flickering light
This means the supply to the lamp is intermittent
What can cause this
Loose wires - but where. It could be in the next room where the feed from one ceiling rose into the next rose comes from
It could be in the switch or the switch itself making intermittent contact
What about the light fitting itself
A flashing lamp could and many times does point to wear in the lamp holder itself
I would sugggest changing this before taking lessons on multimeters
