Can I use this for example?
http://www.tlc-direct.co.uk/Products/SK661406.html
RF - thanks for the detailed wiring info for the relay - can you just confirm that by using the relay (which is effectively the 'switch', yes?) I could use a normal 2A rated doorbell push and bell wire for each of the bells? I would need a transformer with output enough for 4 bells though?
Hmm -just re-read that and I'm not sure now... enough current is still required to operate the bells which if they are looped off each other would larger cable not be required? Think I'm a bit confused...
With the relay you have the bell transformer(s) (or battery(ies)) close to the bells, so voltage drop is minimised.
I think the plain piezo buzzers sound rather unattractive and I would suggest something like a
http://uk.rs-online.com/web/p/sounder/1967487/
connected up to give a 'yodel' tone. Power is 12 V DC at approx 25 mA and they panel mount so you could drill a blanking plate to match the other electrical accessories.
Alternatively use a relay from the bell push to run mains powered fire-bells.
