Must my fuse box be replaced?
2 Jul 2003
We are having a new bathroom fitted and as part of that there is a fair bit of electrical work.
We have had a survey by the contractors and have been informed that our fuse box needs to be replaced as it doesn't have an RCD, and Part P has been quoted at me.
Powergen's best advise was to "search the net" :eek: ! Thanx - I had thought of that myself!! :mad:
The fuse box is a Wylex branded thing, with 4 "re-settable" fuses and an on-off switch (appologise for the idiots terminlogy :oops: ).
Can anyone advise if this is correct or am I being taken for a ride?
To comply with current regs all socket that can be used for outside equipment and showers must be protected by a RCD.
They could fit a single RCD to supply the shower, housed on its own.
Thanx Qedelec, I put this to them and see what they say.
Oh, how I wish I understood more....
Qedelec said:
To comply with current regs showers must be protected by a RCD.
Which reg number is that? ;)
And anyway - the IEE regs are not mandated by Part P.
HOWEVER - RCD protection for sockets and the shower is Very Good Idea, so you should have it done. But you can't be forced to, unless it's a TT supply, and then there is always the option of adding a standalone RCD to the installation.
Notwithstanding #9, how much have they said the new CU will cost?
