There is nothing wrong with that Consumer Unit.
A good setup
A good setup
Indeed. I'm a little surprised that "whilst they were at it" they didn't also give that 'Downstairs Lighting' (if there is an 'upstairs'!) an RCBO. I can but presume that, as eric has suggested, it's surface wired and they saw it as a way of saving a few quid! However, if it were today and if that circuit supplied a bathroom light, it would actually be required to have RCD/RCBO protection.There is nothing wrong with that Consumer Unit. A good setup
Indeed. I knew that, but my fingers typed the wrong thing I know that I knew it because I did 'wonder' when making my comments about bathroom lights - but then I decided that, even if it does have an 'upstairs', if it's a flat, it could well have a 'downstairs' bathroom! It was probably anticipating typing "(if there is an 'upstairs')", which is what I intended to type (and did type), that confused my typing fingers! Other than the correction of the typing, my comments remain the same.It's the downstairs that doesn't have an RCBO
At least 45 (wo)man-days, then ... I would agree that sounds a little 'surprising', at least to me!the contractors I feel are doing works to gain money from the council they are saying it takes up to 15 days to fit a new kitchen and rewire and there is at least 3 people in doing the jobs ...
IIRC, prior to BS7671:2008 (aka '17th edition') coming into force (which, again IIRC, was around mid-2008), RCDs weren't required for much at all - not even sockets if they weren't ones 'likely to be used for outdoor equipment', and not (again IIRC) buried cables. However, the fact that there are all those RCBOs (even more expensive back then) suggests that the "17th edition" may well have been in force at the time the CU was installed, doesn't it?From memory, in the first part of 2008, RCDs weren't required on lights, were they?
I can believe that - and it would have been two bad with RCDs. However, we are talking about (mainly) RCBOs which, back in 2008, RCBOs were pretty expensive, presumably even in bulk ... and that does not really explain why the put RCBOs on four of the circuits (one of which was lighting), leaving the final circuit with no RCD/RCBO protection at all.Im guessing but I vaugely recall something happened and the councils had a purge on fitting Rcds on virtually all sockets regardless of regs.
I can believe that, too!I recall our local wholesalers used to issue a made up kit allocated per property regardless if it needed it and the subbies had no say and had to fit it and the tenant sign for the work
15 DAYS to fit a kitchen with 3 people involved?the contractors I feel are doing works to gain money from the council they are saying it takes up to 15 days to fit a new kitchen and rewire and there is at least 3 people in doing the jobs which is a joke
