Hi there - I'd be grateful for any advice on the following.
I'm planning to fix a 3/4 inch thick piece of wood to the wall either side of the top of our staircase, which will enable me to install a child safety gate. (It's either that or take away the skirting board below.)
From tapping the wall I assumed it was plasterboard, and I managed to get self-drill plasterboard fixings in at two points. However, when I tried putting in the other fixings (two inches to the left) it seems that there is a thin layer of plasterboard, followed by a cavity, then a masonry wall.
I've now messed up the plasterboard by punching through it (I know, I should have tested it with something thinner first) and I don't know what to do next. Should I fill the holes and then drill through? Is there some sort of fixing that will go through (roughly) a quarter-inch of plasterboard and a a quarter-inch cavity followed by masonry?
Apologies if this sounds obvious, but I am a DIY novice!
