canduit
You got me thinking now. What you say is perfectly sensible, here's why..
Im in a flat but its the top flat with only one other below me, so I have the roof space attic and my own front door etc. I use the loft a lot for storage etc and have put boards down so I can walk around.
Now on 3rd January I was hit by 100+mph winds that removed a good part of the tiles from my back roof. So I was up and down the loft a lot during the repairs checking for leaks etc. Up and down like a brides nighty I was! Its reasonable to guess I have worn through a cable sandwiched between loft baords and joists. That might explain the inconsistency in the fault.
I will go up later and root around and see what I can see.
Now question...if the problem is the cable how do I know that it should be between consumer uint and shower switch as opposed to shower switch and shower? Am I missing something obvious here??
I think I will hold off on the multimeter for now...
Cheers
Cheers
