Hello. Problem situation is a Myson Apollo (30Si). It has been in use for probably about ten years. Although working fine, it has started to make a lot of noise. On opening up, it certainly seems to be the fan assembly that is the culprit. The bearings, etc. are free running, but there seems to be vibration on the mounting. For example, applying a small amount of pressure to one of the three rubber mounting sections around the fan / blower wheel assembly cuts the vibration/noise completely.
The fan itself was replaced two years ago and there does not seem to be any problem with that. This suggests to me that the blower wheel / fan assembly is become slightly unbalanced or similar. Does anyone have any experience of rectifying this sort of problem?
Thanks in advance.
Thanks in advance.
