Myson Thermostatic Radiator Valve Head
2 Jan 2008
Hertfordshire
I've broken the head of a Myson Thermostatic Radiator Valve. Its about 15 years old. Myson no longer stock this valve. Does anyone have an old one they could sell me? Nicola
Even though the actual valve has been discontinued you should be able to get a head to fit; www.heatingcontrolsonline.co.uk supply heads for Myson valves. I have had the same problem and ordered one from them today (how I came across your query). If you want to wait a few days I'll let you know if it works.
Trevor
Hi Trevor, I too have contacted the same people. I called Myson and they said I have to order an adaptor too. Apparently you will need to order these two items.. 2TRVHEAD and 2TRVADAP then it will work! I'm waiting for them to call me when they have one in stock. I'll call them again today to chase them. Thanks. Nicola
Trevor, I just called them, and Matthew said they will be in in about 1 weeks time, so you might want to put your order in too! You will need the adapter. thanks. Nicola
